As different things Madrix map DVI
Dear friends.
DVI Madrix recently bought my provider in Argentina.
The issue is this, as I can not count on the support or assistance needed, I ask if I can give solution to a problem that I have encountered.
4 styles need to generate different mappings, allowing reprodusca each the same or different things.
I have an event where I will install a floor led (pich 20) of 20 m2.
Measures: 5m x 4 m
Dj cabin
Dimensions: 4m wide x 2 meters high
2 towers of LED
Size: 1 m wide x 3 m high
Front LED that will be located near the hagasajados table.
Measures: 1 meters high x 4 meters wide
I could help you understand how I can generate different arrays or mappings to play different things in each of them. Or the same.
Remember to have a unique key DVI MADRIX
I am waiting for your prompt response.
thank you very much
Sebastian
I await your response.
Measures: 5m x 4 m
Dj cabin
2 towers of LED
thank you very much
Sebastian
Re: As different things Madrix map DVI
For this, you have to use multiple layers, where each layer is maped onto the size and Position of your patch where the LEDs are loacted for the specific Region.
With this you can run different effects (on the different layers) on different LEDs.
Without mapping you can run one effect over all LEDs.
Please read in the online manual of MADRIX how to map effects.
http://help.madrix.com/hidd_map_dialog.html
Sorry to bother you, but I find it hard to understand or follow the steps in order to generate different visual or the same in different structures.
Could guide me or show me some video reference.
Thank you very much.
my college should send you a email with a Video link.
I understand we can map different effects on layers mapped to the corresponding regions so with a single madrix controller we may have different effects on different regions,
My question is the following; is it possible to have the transition timings vary between different regions maps, or do we have to have a transition at every layer simultaneously?
Different Timing on differnet Areas you can only achieve with different MADRIX running.
If one MADRIX run different Areas at the same time, you can only Change all by one.
I thought so, thank you very much..
