How to make autorun of Main Output Macro?
Hello!
We have made Main Output Macro in MADRIX 2.12a.
How can we achieve autostart of it at the moment of Madrix loading?
System must work without human interaction.
Re: How to make autorun of Main Output Macro?
The Main Output Macro belongs to the Setup.
So if you set up the start Options of MADRIX to load a Setup with a main out macro (which runs in the Moment the setup was saved) it will start autoamticaly if the Setup is loaded.
Thank you very much!
But, in my opinion, the such behavioral logic is non-obvious.
And, by the way, we plan to explore other types of Macro in the future...
Please explain this a Little bit more in Detail, so we have a Chance to think about it for future development.
I mean, if there is and can be only one Main Output Macro, it must be autostarting. Or there should be some CheckBox or other dedicated control to define running status of this Macro upon loading. I think, dependency of Macro's next time loading autostarting from its running status during the Setup file saving is not so clear.
I can say nothing about other Macro types. We have not use them so far, only plans exist in the theory. I shall ask questions in the process, if they will be.
Ok, if i understand you correctly, you like to see a seperate Option in the start Options of MADRIX, if the Main Output Macro should start (if exists) or not. And the Default will be it starts, right?
Yes, you are right.
