Version 3 button font.
reporter
Post by reporter »
I have a number of installation which use 15" touchscreens. These screens all run at 1024 x 768 which used to be the default resolution for Madrix.
I know that it's a pretty low resolution by today's standards, but with the new version, at that resolution, none of the buttons show a number to identify them. They are all just blank buttons. Can you add a smaller font or something so that numbers will show up, or is the only option to view it as 2x2, which only shows 16 storage places?
Thanks,
Nathan
Re: Version 3 button font.
Hi Nathan,
The 2x2 view does only show 16 Storage Places. But you can use the slider below them to bring the other buttons into focus. Is that acceptable enough?
(Even when using 1280 x 768, the 8x8 view was introduced to show all buttons and by default this view has also no index numbers.)
Also, please note that the system requirements for MADRIX 3 have changed and now require a screen resolution of 1280 x 768, for example.
Thanks,
Martin
