Editing Fixtures
Editing Fixtures
Hi guys is it possible in the madrix fixture editor to change colour channel number ? ie .. I would like to make a fixture that uses 3 channel BRG instead of RGB. I cant seem to get it to changed and stay changed. Thankyou
Re: Editing Fixtures
Yes, that is possible.
Please configure your fixture as required and make sure to set up the following items as explained:
First, please set Color Depth to 3 in the "Fixture" section. The Fixture Editor will automatically set it to RGB, but please do not worry about this.
In the "Channel" section below, you can then add each individual channel. Simply add "Color #" to Blue for channel 1, to Red for channel 2, and Green for channel 3.
When, finnished press OK, save the Fixture Library, and restart MADRIX.
Does that help?
Does that help?
