Patching Madrix to ignore channels?
Hi. Looking for some help patching Madrix to ignore channels.
I want to run two universes with 144 generic RGB pixels on each - so 432 channels on each. How do I patch Madrix to ignore channels 433-512 on the first universe i.e. skip from channel 432 on universe 1, to channel 1 on universe 2?
Any tips much appreciated!
Re: Patching Madrix to ignore channels?
I Gues you patched with the Matrix Generator (which is almost the same dialog as like as the add fixture dialog in the patch window).
After you generate your patch you are able to change the settings inside the patch window.
Select the fixtures of your interest and change the universe and channels.
Maybe it is faster to rebuild the patch.
First add the first 144 RGB Pixel into the patch with universe 1 and than insert the next on universe 2.
thank you very much, it seems obvious now!
