DMX Watcher
cg
DMX Watcher
Post by cg »
if you change Win7 to use larger fontsize 125% (what is quite useful on touchscreens) the DMX Watcher does not scale the surrounding window and the last line will be cropped, so you can't see addresses 497-512. There is not even a scrollbar.
Normally I use the last channels for remote DMX control, so it would be nice if this could be improved.
thanks
(zu finden unter: Systemsteuerung - Anzeige - "Lesbarkeit auf dem Bildschirm erhöhen")
Re: DMX Watcher
Hi cg,
thanks for this hint we will take care about this in a future release.
