Crash when using high speed commands in Remote Control
viennaxmas
Post by viennaxmas »
I am trying to use Madrix to control a 35 *96 matrix. Madrix is controlled via DMX Input on E1.31 / SACN.
The problem is that Madrix is crashing if the sequencer sends high speed commands (about 10 changes per second). Madrix 3.1 keeps up for the first 10 changes and then reproducible crashes. :(
Channel 3 is the "Storage Left Place" command.
12/4/2013 9:50:49 AM Channel 3 Level 4 Source Comm Listener
12/4/2013 9:50:49 AM Channel 3 Level 6 Source Comm Listener
12/4/2013 9:50:49 AM Channel 3 Level 1 Source Comm Listener
12/4/2013 9:50:49 AM Channel 3 Level 2 Source Comm Listener
12/4/2013 9:50:50 AM Channel 3 Level 4 Source Comm Listener
12/4/2013 9:50:50 AM Channel 3 Level 6 Source Comm Listener
12/4/2013 9:50:50 AM Channel 3 Level 1 Source Comm Listener
12/4/2013 9:50:50 AM Channel 3 Level 2 Source Comm Listener
12/4/2013 9:50:51 AM Channel 3 Level 6 Source Comm Listener
12/4/2013 9:50:51 AM Channel 3 Level 1 Source Comm Listener
12/4/2013 9:50:51 AM Channel 3 Level 2 Source Comm Listener
12/4/2013 9:50:51 AM Channel 3 Level 4 Source Comm Listener
12/4/2013 9:50:51 AM Channel 3 Level 5 Source Comm Listener
The storage places all contain different "Color Scroll" so nothing to complicated to load.
Is there any known limitation on the number of changes I can send per second?
Re: Crash when using high speed commands in Remote Control
Hello!
Thank you very much for your report!
Unfortunately, it is currently a confirmed bug in the software that it can crash when switching very quickly between Storage Places. We will be working on a fix, which will be available with one of the next updates. We are very sorry that it happens.
viennaxmas
Vielen Dank! Fuer den speziellen Fall habe ich erst mal ein MAS Skript geschrieben, das den gleichen Effekt erzeugt und damit geht es bis eine neue Version verfuegbar ist. Eventuel ist das eh die bessere Methode fuer so schnelle Effekte.
Was mir noch aufgefallen ist, ist dass es besser funktioniert je weniger UI Elemente verfuegbar sind...
Danke für Deine Hinweise viennaxmas, das werden wir bei der Fehlersuche mit einbeziehen.
MADRIX 3.1a wurde soeben veröffentlicht. Könntest du es bitte mit der neuen Version testen? Vielen Dank!
