Can not hold the select effect drop down manu
start from 3.0a , I can not use the mouse to select effect, unless use the down arrow key to hold the menu, thanks a lot to help me to solve it !
Re: Can not hold the select effect drop down manu
Hi hing88008,
Thank you very much for your report! We haven't heard of this before.
Can you please contact us at info[at]madrix.com?
If possible, please send a short video of the issue and please create a MADRIX Logfile ( In MADRIX, go to Tools > Logfile > Save To File... and enter a name for the Logfile. Please send us the file by e-mail. )
Is it working with MADRIX 3.0?
Hi hing88008,
Did you use a mouse or a touch device?
i have the same problem(window xp sp3) ,but it works well in WIN 7, i don't why
same question heibai,
mouse or touch ?
mouse or touch ?
i just use the mouse , no touch
What is your screen resolution?
Is it below the MADRIX system requirements?
the screen resolotion is 1440 X 900 (recommand),it just has the problem in Window XP,.
in Win 7, it is OK,the same screen resolotion.
but when i restrore the Win7 to Window xp, the problem happens again
Ok, and did you run the MADRIX window maximized or in the default size which did not cover the whole screen?
