dmx in and timecode
cburgin
dmx in and timecode
Post by cburgin »
I am new to madrix. I get how to program it and make cues. I have a Hog IPC running in hog3 mode controlling a light show to smpte timecode. I want to add madrix to the show. cAN i put smpte timecode in the show or can i trigger cues from the hog 3 cuelist? if so what all do i need to do either?
THanks chris
Re: dmx in and timecode
Welcome to the Forums!
Both is possible with MADRIX.
The Cue List of MADRIX can receive "External" Time Code. It supports Art-Net Time Code or MIDI Time Code. You can learn more here: http://help.madrix.com/m3/html/madrix/h ... list_.html
Regarding Remote Control, among others MADRIX supports input via DMX-IN or Art-Net Remote. You would either need an DMX-IN interface (such as the MADRIX USBone with an XLR adapter) or you could connect via Ethernet network, depending on what your console outputs. You can then create your individual DMX remote protocol or use one of the 3 preconfigured mappings. Learn more here: http://help.madrix.com/m3/html/madrix/h ... l_dmx.html
