Fade time in video
Lightsolutions
Fade time in video
Post by Lightsolutions »
I tried to play a video on a led cube. But I can't find a way to make a fade in the leds. Does anyone now?
Re: Fade time in video
Hello Lightsolutions,
At the moment there is no control at the "SCE Video" effect for Fade In or Fade Out a video.
If you want to Fade In a video you have to write a Macro for this effect.
Here you can learn more about programming a Macro or Script in MADRIX:
http://help.madrix.com/m3/html/script/index.html
The function you will need is called: DimPixelArea3D. This function provides the possibility to dim a desired area and you can create a fade in for your effect because you can increase the dim value.
