font type
yersiu
font type
Post by yersiu »
Hi! here's my problem! when I try to change the font type a message says that i have to install the fonts opening the fonts folder on the control panel. I have try it but I can't.. :? How can i do it???
Thank
Sergi
Re: font type
Hi yersiu,
In order to help you, can you please help us first by answering a couple of questions:
- Which font are you trying to use?
- Is this font already installed on your computer?
- Which MADRIX software version are you using?
- Which Windows operating system is installed in your computer?
If possible, could you send us a screenshot of the error message to info[at]madrix.com please?
Thank you very much!
yersiu
Re: font type
Post by yersiu »
- I'm trying to use any Font, is not only one font.
- Yes, I have installed all the window fonts again, but the problem already exist.
- Actually I'm using the las version of madrix3
- The operation system is windows vista
I use the madrix2 version at the same computer and this problem doesn't exist.
I'll send you the screenshot of the error message (it's in spanish)
