DMX watcher don't view more then 8 universes
dieter
Post by dieter »
I have test the my new installation with 12 universes of DMX and a patch solution 60x34 pixel. I will check all this universes with the DMX watcher of MADRIX. For universe 1...8 all values right, but 9...12 don't view the right value. All fixture view the right color an running fine. I only have test with the NO MADRIX KEY version, because the original key is on tour.
If different between a version with key and without key?
Is the DMX watcher limited to 8 universes?
It is a bug in DMX watcher?
Pinzer
Re: DMX watcher don't view more then 8 universes
Post by Pinzer »
Hi dieter,
yes, this is bug. It will be fixed in the next version, which hopefully comes out this week.
Thanks for reporting it!
Hi Dieter,
Please check out the newest update for MADRIX, which we just released (MADRIX 2.13b).
dieter
Post by dieter »
running fine now
