Hue performance is super slow
Hi! I just upgraded to Madrix 5.5e to take advantage of the Hue integration. I have an isolated network that Hue is plugged into. 2 different bridges. Bridge 1 has about 40 bulbs. Bridge 2 has about 15. Lights are patched and working, but I have to configure for bridge for 1000ms. If I configure for anything else it seems like the commands get queued up and it takes forever for the lights to become responsive again. It also looks like there is a default transition or fade applied, even thought that's not that I have configured in Madrix.
Simple test. Configure a Cue as SCE Color Change. Disable fade. 60 BPM. Time 1. The bulbs should snap between colors. Instead there is a fade applied. Video showing configuration and output follows https://citrix.sharefile.com/d-s06b5cb4 ... 320db42435
I really expected to see much better performance than this. Hopefully this is configuration or perhaps something in the software that can be fixed.
Re: Hue performance is super slow
Thank you for your post.
Could you please let us know which fixture models you are using?
On the one hand, let's look at what the software is able to do and on the other hand how the hardware is capable of performing.
I have the impression that the Hue fixtures and bridge simply cannot perform in the way that you are expecting.
You are mentioning the 1000 ms, which indicates 1 frame per second. I think that is what your are experiencing and what your video shows. With high-performing LED fixtures and controllers, the MADRIX 5 Software would be able to send data to the fixtures much faster.
I'll also ask the developers if the developer API provides any new features since their last update.
Philips themselves indicate these performance characteristics. Please see:
https://developers.meethue.com/support/
I have received additional suggestions:
The more lamps are controlled by a bridge, the lower the frame rate will be.
Please try to control a maximum of 10 lamps per bridge. In our tests, we could achieve 100 ms / 10 FPS in this way.
And please note that more load is added to the WiFi, the more bridges are used. Spacing them out can help in reducing interference.
I did a bit more testing last night myself. I removed lights from the patch and found that I can get about 12 decently performing on a bridge. I enabled the 2nd bridge and repeated the same test. Anything more than 12 and the performance drops off considerably.
I really don't want to have to run 4 bridges for my setup if at all possible. That's 4 Universes for 48 lights. Super wasteful. Controlling in Madrix would be no problem, it's the everyday control via the Hue app and home automation that'll be more difficult then. Hopefully there are some updates to the APIs or maybe even a better Bridge that could handle the load.
The fact that the Hue Bridge is limited to 50 lights is already bad enough.
One more question. The AURA isn't capable of sending data to Hue, correct? Once I have everything setup I'm going to want a scheduling and playback device.
