HTTP control of daylight savings
Quinton
Post by Quinton »
Hi Team,
Would it be possible to get a full list of all http commands for latest firmware 1.16?
I currently would like the command to turn daylight savings ON/OFF but would be great if had all the commands to use :)
Re: HTTP control of daylight savings
Hi Quinton,
You can turn on/off the daylight saving time with the following command:
Code: Select all
http://[IP]/config.shtml?daylight=n
to turn it off
Code: Select all
http://[IP]/config.shtml?daylight=y
to turn it on
We can't come up with the list, since it could change with every new firmware version.
Quinton
Post by Quinton »
Thanks Shulze
