Madrix with pixel strings - wrong output to Univ 2 ch1-15
heystew
Post by heystew »
Setup:
- SanDevices E682 with 15 strings attached. Each string is 25 pixels
- String 1 starts with universe 1, the last string finishes half way through universe 3
- the transition from Universe 1 to 2 is mid-string on String #7
Problem;
- the first 5 pixels of each universe (2 & 3) seems to be getting skipped. (the universe seems to start at the beginning of the next string. I swore it had to be configuration of the E682, but the config is right, and it works from SACN view
Example
- screenshot of madrix patch and preview, and SACN viewer available here: http://www.rockyrunchristmas.com/pics/MadrixMixUp.pdf
- test setup - all red except for the 5th pixel down on all 15 strings is set to green
- Universe 2 - Pixel 1 is set to green in preview
- PROBLEM: Universe 2 - Pixel 1 shows a value of 255,0,0 (red) in SACN view
- when i test with SACN view sending data to Universe 2 - pixel 1, it works as it should.
Any help or recommendations appreciated.
thanks!
Dave
Re: Madrix with pixel strings - wrong output to Univ 2 ch1-1
Hello!
The first thing that comes to mind is the DMX Fader Tool. Please double-check if it is fully deactivated as it overwrites DMX channels. In MADRIX, please go to Tools > DMX Fader Tool.
Since that might not be the solution, can you please send us your MADRIX Setup File to info[at]madrix.com and please include the details you wrote in this post.
This will help us to help you. Thanks!
heystew
Post by heystew »
Thank you for the quick reply. It does not appear to be the DMX fader.
I have sent you the setup files.
thanks again,
dave
heystew
Post by heystew »
Problem resolved thanks to Martin's help. Universes 2 and 3 were improperly configured in the DMX preferences.
thanks,
Dave
