more then 256universes, can I use 2 key ultimate
phoenix
Post by phoenix »
I'm new to Madrix.
We have one project need more then 256 universe, and use ArtNet controller. And don't want to use DVI output, Can I use 2 key ultimate? :?:
If yes, what's the requirements on PC.
Looking forward to hear from you.
Thanks.
Re: more then 256universes, can I use 2 key ultimate
Hello phoenix,
Yes, you can do that!
In order to realize such a large project, a couple of tips should be noted:
- When you want to use more than 256 DMX universes, you need to tell this the software:
Go to the menu 'Preferences > Options… > tab Performance >section Virtual DMX Universes'. Set 'Output' to the required number of DMX universes.
The right equipment is also important:
- a high-quality, managed network switch should be used (1 GBit/s)
- high-quality computer network card should be used (1 GBit/s)
- high-quality network components and Art-net controllers should be used (MADRIX LUNA devices are made for this)
- Direct IP Mode should be used in MADRIX for each Art-Net device (instead of Broadcast Mode)
- The computer needs to be powerful enough. Please see here for recommendations: http://help.madrix.com/m3/html/madrix/h ... ments.html
phoenix
Post by phoenix »
Hello Fritzsche,
Thanks for your help.
