Expansion port
thomasss
Expansion port
Post by thomasss »
I am not sure if this is possible but this is what i would like to do:
The plexus should play an effect that gets manipulated by the digital inputs on the extension port. For example speed and intensity?
Would it be possible to access the digital ports within a script file??
I couldnt find any documentation about this.
Re: Expansion port
Hello thomasss,
With the help of the digital input of the PLEXUS "Extension Port" you can change the value of the speed and intensity to desired discrete values in stand alone mode.
For example you want to set the intensity to 50% you will need one switch and when you want to set the intensity to 100% after a several time you will need an other switch which is connected to other pins of the "Extension Port".
Also you have to configure the processing of the "Extension Port input" in the MADRIX software at the "PLEXUS Configuration" dialog. To open the "PLEXUS Configuration" dialog please start MADRIX and go to "Tools > PLEXUS Configuration". It is not possible to use a script to change the assignment of the "Extension Port" settings.
In the following links you can learn more about the PLEXUS extension ports and how to configure it in the PLEXUS Configuration dialog:
http://help.madrix.com/m3/html/plexus/i ... _port.html
http://help.madrix.com/m3/html/plexus/i ... confi.html
