DMX and Madrix
Matthieu
DMX and Madrix
Post by Matthieu »
i recently got madrix for dmx.
i played with it and did some shows and noticed that there is no way to keep the dmx level across storages for the submaster, unless i over looked something.
for live shows its best when you turn down a submaster to open a new effect that that affect is also turned down, not on the last submaster level.
if this is currently not posible could u make a feature that you can activate this for dmx?
Thanks in advance,
Matthieu
Re: DMX and Madrix
Hello Matthieu,
You are right, the Storage Place Submaster in MADRIX is assigend to each Storage Place and also independently from all other Storage Places in MADRIX.
Can you please explain a bit more what you would like to do with such a kind of submaster?
Maybe it is possible to use the Main Output Master for this task?
Matthieu
Re: DMX and Madrix
Post by Matthieu »
guertler,
i use madrix to controll a backwall with 1000 pixels in a theater show.
i would like to be able to switch storages from one side and keep the level of the storage the same as the previous one, that way i can use the right side storage to use as a background color, and switch the left side for efects over the other color.
also i use a the color filter to change colors.
but now it switches to what ever the last setting was of the submaster.
so if i have a lowlight scene, it will be to much, and the other way around.
i want to be able to have the 2 side submaster each on a dmx fader so i can have to intensity under my hands if you understand?
if i use the master i can not easely do this.
Re: DMX and Madrix
Hi Matthieu,
we working now on the submaster for left and right side. This feature will be avaiable with MADRIX 3.5
Ismal
Re: DMX and Madrix
Post by Ismal »
@Matthieu
In the mean time, maybe you can set the cross-fader to 75% when you know the next effect is to bright. You could just not cross-fade all the way, it would be a way to 'cheat'.
Matthieu
Re: DMX and Madrix
Post by Matthieu »
Thanks for adding this to the program!
This will realy help.
Also thanks for the tip!
Matthieu
Matthieu
Re: DMX and Madrix
Post by Matthieu »
Ismal,
can you tell me how to activate this feature in the new software?
thank you
matthieu
Re: DMX and Madrix
Hi Matthieu,
i am sorry, this feature got a delay in the development. We working on it to release it with MADRIX 3.6.
Matthieu
Re: DMX and Madrix
Post by Matthieu »
hello Wissmann,
do you have an eta on the next release?
thanks in advance
Matthieu
Re: DMX and Madrix
In April at the Prolight we hope to have the next RC
