Philips Color Kinetics / iPlayer
MaxMadrix
Post by MaxMadrix »
Hi
First post here.
I am setting up a 4 universe (Luna most likely) lighting system with Madrix software. I have a separate Philips Color Kinetics system using an iPlayer 3 and auxbox. How do I determine whether I can control the CK system through the same Madrix software?
Thank you
Re: Philips Color Kinetics / iPlayer
Welcome!
Does the iPlayer support receiving KiNET from a third-party controller?
Here area couple of points to start with:
1) I would recommend to download the demo version of MADRIX and test the KiNET system with it.
2) Since you are likely to run two network protocols (Art-Net for the LUNA 4 as well as KiNET), it would be necessary to use 2 separate network cards.
3) In MADRIX, you can then activate both protocols and configure your devices in the Device Manager > DMX Devices as needed. Before that, you would have set up your lighting fixtures in the Patch Editor.
Does that help?
Thanks! Martin
