How to use Madrix with Akai MPD32
Lowyr2
Post by Lowyr2 »
I got a AKAI MPD 32 and tried to use it with Madrix, the problem is equal which button i use there is no reaction, how can i map the controls onto the buttons, or isn´t it possible to use this kind of MIDI Pad with Madrix
Re: How to use Madrix with Akai MPD32
Hi Lowyr2!
Thanks for your question!
Right now, with MADRIX 2.9, you will not be able to use this MIDI controller.
But don't worry! A new version of MADRIX is already on its way.
We are going to offer a test version (BETA version) very soon and you will be able to try the AKAI MPD 32 with MADRIX.
Once this version can be downloaded, you will be able to learn how to map the controls onto the buttons using the MADRIX Help and Manual (user guide). The chapter is called INPUT -> MIDI-IN.
PS, you will always have to enable and configure your MIDI controller in the so-called Device Manager of MADRIX before using it.
We have just released a test version for this new feature (MADRIX V2.10 BETA).
Tell us what you think!
