DMX usb and more
shasha
DMX usb and more
Post by shasha »
I use Madrix 5 start and ENTTEC DMX USB Pro. I install the driver of the enttec and update firmware using DMX PRO Manager. Unfortunately in Preferences > device manager > DMX device there's no enttec controller.
I noticed that in prefenrences > Options > Devices USB there's no FTDI Device Driver
https://ibb.co/kJOc8z
Is this my problem? How can I solve it?
other problem... i can't find MA 2Port Node, should i enable MA Lighting - MA-Net in Device Network?
Thanks in advance
Re: DMX usb and more
Hello shasha,
MADRIX 5 does not support the "ENTTEC DMX USB Pro".
Under the following link you can find all supported DMX interfaces of MADRIX 5:
http://help.madrix.com/m5/html/madrix/i ... faces.html
If you want to use a USB to DMX interface in MADRIX 5, you have to use a MADRIX interface like the USB ONE
https://www.madrix.com/products/usbone
If you want to send the data via Art-Net or sACN out, you can use every compatible Art-Net or sACN interfaces on the market like the LUNA or STELLA.
https://www.madrix.com/products/luna
https://www.madrix.com/products/stella
It is also not possible to use the "MA 2Port Node" as output interface in MADRIX. The "MA 2Port Node" is working with MA-NET and MADRIX can only listen to MA-NET but not send data to this protocol. That means you can use a MA-Net connection to control MADRIX remotely but not for sending data from MADRIX to the MA nodes.
shasha
Post by shasha »
is to be too restrictive
bad choice for me
bye
Thanks for your feedback!
