Animations lagging and are slow
Pecanac
Re: Animations lagging and are slow
Post by Pecanac »
Hi Pinzer,
I have finally began to make animations and everything for the project I was talking before in forum. I configured everything and then encountered a new problem that I don't know how to fix.
When PLEXUS is connected to Laptop animations on both universes DMX1 and DMX2 are working without a flaw. But when I transfered animations to PLEXUS, and play them from PLEXUS my DMX2 setup doesn't work.
Below is picture of the connection:
http://prntscr.com/lftnna
What did I do wrong when transfering to PLEXUS?
Pinzer
Post by Pinzer »
Hi Pecanac,
my first intention is, that there are something wrong during the the confersion to the dxd files. Maybe you only convert 1 Universe. Here you can find the manual to check if you are made all right http://help.madrix.com/m5/html/plexus/h ... files.html
You can also check if the data play data an the Dmx 2 Port when you open the DMX 2 Monitor under Tools on the PLEXUS.
If you can't find an error maybe you send us, the files you exported to the Sd Card to our email info @ madrix.com. So we can check it.
best regards,
Sebastian
Pecanac
Post by Pecanac »
I checked and can't find I will send via email.
Thank you
