Two matrices synchronously?
Hey Madrix Community,
My question is: How can I control two matrices synchronously?
Specifically: I have two different sized matrices on which I want to run the same video in sync,
So no overlapping of the pixels.
I hope it's possible in such a powerful tool as Madrix.
Greetings Lucas
Meine Frage ist: Wie kann ich zwei Matrizen synchron ansteuern?
Konkret: ich habe zwei unterschiedlich große Matrizen, auf welchen ich absolut synchron dasselbe Video ablaufen lassen möchte,
Also kein überlappen der Pixel.
Ich hoffe, dass es in einem so mächtigen Tool wie Madrix möglich ist.
Greetings Lucas
Re: Two matrices synchronously?
Hello LTMbyKBL,
When you want to playback two times the same video on different fixtures, you will need to work with more than one layer and the mapping. Now the layers must be mapped to the desired places and you have to load the video(s) at both layers.
Under the following links you can learn more about to work with layers and the mapping in MADRIX:
http://help.madrix.com/tutorials/html/i ... ayers.html
At the moment MADRIX will start both layers at the same time but it will not send sync commands between the two played videos during the playback.
