5.3b Device Config not seeing Luna
JasonCA
Post by JasonCA »
I think the new firmware for Madrix 5.3b breaks the setup menu for the Luna nodes. I rolled the firmware back to 5.2.1 and it works fine. I can access either through the node's IP address or the Device Configuration in Madrix.
With the 5.3b firmware the Luna nodes do not populate in the Device Configuration window.
Rolled back to 5.2.1 and they do.
Re: 5.3b Device Config not seeing Luna
Hi JasonCA,
The issue has been fixed with the release of MADRIX 5.4.
Please download the updated version here: https://www.madrix.com/download/MADRIX_Full_Install.exe and perform a firmware update for your MADRIX LUNA devices.
Hi videoanger,
There was an issue in an older MADRIX LUNA firmware, which leads to the MADRIX LUNA not appearing in the "MADRIX Device Configuration" menu. However this issue has been resolved some time ago.
In order to update firmwares for MADRIX hardware devices, please use the MADRIX HARDWARE MANAGER.
Here you can download the MADRIX HARDWARE MANAGER:
https://www.madrix.com/download/MADRIX_ ... nstall.exe
Here you can learn how to update firmwares:
https://help.madrix.com/hardwaremanager ... dates.html
