Interface Français - options d'enregistrement inversé
andyesl
Post by andyesl »
V5.4
REC ( enregistrement ) options
les options enregistrement ont inversé
pour enregistrer vers un AURA par réseau, c'est nécéssaire de sélectionner " Enregistrement MADRIX "
" Enregistrement de réseaux " créer un version local.
ce problème existe aussi en modes portugais, Italien et Turque.
RECORDING options bug.
was ok in 5.3b but is wrong in 5.4
the Madrix recording and Network recording option labels are inverted in French, Portuguese, Italian and Turkish interfaces.
at present, in order to record via network to an AURA it is necessary to select "MADRIX" as the target in order to activate the network record options when using MADRIX in these UI languages.
the functionality is fine, it appears that it is just a labelling error in V5.4.
all the best
Andy
ESL France
Re: Interface Français - options d'enregistrement inversé
Hi Andy,
Thank you for your report.
I will hand it over to the software developers.
