edit fixture and load/save new
dieter
Post by dieter »
Hi MADRIX team,
I found two problems in fixture editore.
First if you changed a loaded fixture and than press new or load library then no warning for unsaved library. But if you press exit, than show warning.
The second problem is if you press new button after loading library than make the library new, but in top line in window is the old file name. When I press save button now, than destroy my before loaded library.
I think are bugs in fixture editore.
Re: edit fixture and load/save new
Hi dieter,
thx for this report.
We will check this out and take care about it as soon as possible.
fixed in version 2.13
dieter
Post by dieter »
happy waiting done
dieter
Post by dieter »
No problems in last version,
Thank you
