Controlling led tube rgb lt-2816 48ch
koymy
Post by koymy »
Hi all, im having trouble with this dmx tube light. Im using enttec usb. I know that madrix dont care anymore about it. The problem is, it seem theres a delay between madrix and the tube. Ive tried to change the fps, standard is 1000ms/1fps . But still not working .IF any of you tried this setup, can u share with me. :|
Re: Controlling led tube rgb lt-2816 48ch
I would recommend to adjust the FPS again. Try a setting such as 30 ms / 33.3 FPS or 40 ms / 25 FPS.
Please also activate 'Full Frames' and test your setup again.
Does this solve the problem?
koymy
Post by koymy »
thanks for replying.. no its not workin delay. the delay is about 1sec
