wiring the led strip to artnet
chuck-kern
Post by chuck-kern »
how do i wire the led strip lights to the dmx out on the artnet node 8 dmx
there is 3 pins on the artnet dmx
pin one = ground
pin two = +data
pin three = -data
on the led strip there is
red = +5volt
black = ground
what are the blue and green? data and clock wired to on the artnet pins
chuck
Re: wiring the led strip to artnet
Hello chuck-kern,
When you want to connect a DMX interface like an Art-Net node to a desired fixture you have to make sure that the fixture is able to receive DMX signals.
The described LED stripe seems not to be able to receive DMX signals.
But some of such LED stripes can be controled via DMX when you will used an additional DMX to SPI converter.
