Input Video fail, i need help
JimmyChanKT
Post by JimmyChanKT »
I am a new user of the MADRIX , When i use (SCE Video) , I input a mp4 video but the program said [Effect Video S2P2L1 Error Loading Video] !!!! what should i do ??
I have been already checked the video , It is fine , but i can't input to the software
And How Can I play more than Two video effect at the same time?
:( :( :( :( :( :( :( :( :( :( :( :( :( :( :( HELP
Re: Input Video fail, i need help
Hello JimmyChanKT,
If you want to playback a video in MADRIX 3, the PC must have the desired codec installed. Also if the video will be played back with another media player. For the playback in MADRIX a codec is required. We recommend to insall a codec pack which includes the codecs for different video sources.
Under the following link you can learn more about the "SCE Video" effect in MADRIX and also the recommended codec packs:
http://help.madrix.com/m3/html/madrix/i ... video.html
To playback more than 2 videos/MADRIX effects at the same time you will need to work with layers and the mapping.
In the following tutorials you can learn more about working with layers and the mapping:
http://help.madrix.com/tutorials/html/i ... ayers.html
