Pendulum/Metronome Effect?
Mordac
Post by Mordac »
What would be the easiest way to create a pendulum/metronome effect? Not looking for a S2L effect, I just need something sweeping back and forth.
Re: Pendulum/Metronome Effect?
Hello Mordac,
Depending on the look of the sweep you will have several options:
Option 1: Using the SCE Graph effect in MADRIX.
  • In the color settings of the SCE Graph effect please delete all colors expected one. Chang this color to the desired color.
  • Change the Frequency to "0"
  • Now you can change the settings for Height, Width Pitch and also the direction
As result a bar will sweep from left to right resectively from top to bottom and back.
Option 2: Using the SCE Wave/Radial effect with a Radar shape in MADRIX. Additinall a so called effect macro is needed.
Attached you will find an example fo a pendulum. To open the attachment please download and unzip it. In the next step please load the MADRIX storage place via right click at a desired storage place and select open in the contect menu. Now please navigate to the location where you have saved it.
To have a look to the macro please open the Macro Editor with a right click at the Macro button and select "Edit" in the contect menu.
Pendulum.zip
(12.23 KiB) Downloaded 2417 times
