Pendulum/Metronome Effect?
What would be the easiest way to create a pendulum/metronome effect? Not looking for a S2L effect, I just need something sweeping back and forth.
Re: Pendulum/Metronome Effect?
Hello Mordac,
Depending on the look of the sweep you will have several options:
Option 1: Using the SCE Graph effect in MADRIX.
Option 2: Using the SCE Wave/Radial effect with a Radar shape in MADRIX. Additinall a so called effect macro is needed.
Attached you will find an example fo a pendulum. To open the attachment please download and unzip it. In the next step please load the MADRIX storage place via right click at a desired storage place and select open in the contect menu. Now please navigate to the location where you have saved it.
To have a look to the macro please open the Macro Editor with a right click at the Macro button and select "Edit" in the contect menu.
- In the color settings of the SCE Graph effect please delete all colors expected one. Chang this color to the desired color.
- Change the Frequency to "0"
- Now you can change the settings for Height, Width Pitch and also the direction
- Pendulum.zip
- (12.23 KiB) Downloaded 2458 times
