No DMX output
rossler@b-r.at
No DMX output
Post by rossler@b-r.at »
Setup: Win11, Madrix 5, 1x Nebula.
Nebula is detected, and configured for DMX Universe 1 to 8 and is online.
https://1drv.ms/u/s!ApA1C-u0A1fVgq8Hrvx ... A?e=QfmgP8
The mapping seems also correct:
https://1drv.ms/u/s!ApA1C-u0A1fVgq8IyZO ... A?e=mwpJ37
But still the DMX monitor does not show a single value (the pixel preview is showing a mix of the two running effects left and right, so there should be some color information for every pixel):
https://1drv.ms/u/s!ApA1C-u0A1fVgq8LWMo ... g?e=3HLY3R
What am I missing?
Re: No DMX output
Hello rossler@b-r.at,
In the first moment it seems no valid MADRIX 5 KEY is connected to the PC.
Is MADRIX unlocked by a MADRIX 5 KEY?
If this is the case, can you please send us the used MADRIX setup and a MADRIX logfile when the MADRIX KEY is connected via e-mail to info[at]madrix[dot]com.
Please navigate in MADRIX to "Tools > Logfile", click the button "Save As..." and enter a name for the Logfile
rossler@b-r.at
Re: No DMX output
Thanks for your answer. A new madrix key is connected but to be activated I need to wait for the reply from my dealer.
However, I was pretty sure I read that madrix is working even without a key provided, but limited to one hour and with the X and the hint about the missing key, floating around.
Re: No DMX output
After activating the MADRIX 5 license at the MADRIX KEY you will be able to send the output data to the connected NEBULA.
In the past with MADRIX 3 (end of life since 2019) it was possible to output data in demo mode. But in MADRIX 5 there is no outout without a valid MADRIX 5 license.
Have fun with MADRIX 5!
