Controlling the Aura via DMX like Madrix 5?
Avocado
Post by Avocado »
Heya folks!
I am trying to figure out capabilities, and haven't been able to find an answer yet.
I am building a lighting show that uses pixel curtains and moving head fixtures. I am building out a timeline using my lighting console. Currently I can use my lighting console to control Madrix 5, but ideally I would be using the Aura controller (a couple in different locations) to output the looks in their areas.
Ideally, this is what I would want to do:
-Create custom scenes/looks in Madrix 5 (images or videos, etc)
-Upload/Install those looks onto a Madrix controller (Aura I believe)
-Using DMX into the controller, call up those looks and set fade types, speed, etc. like you can with DMX into Madrix 5.
Is this possible? Or for the Aura do I just have to record an entire timeline, cuelist, or specific cues and just tell them "go" without being able to control other aspects like fade type and speeds?
Re: Controlling the Aura via DMX like Madrix 5?
Hi Avocado,
Yes, you can create your effects in MADRIX 5 and record them with the MADRIX AURA.
- You can call the AURA cues/scenes remotely similar to Storage Places in MADRIX 5 via Art-Net, sACN or HTTP.
- The AURA allows you to control the intensity and speed of the cues to be played back remotely, but not the fade time.
- Yes, partly. You can change the play back speed of the AURA Cue List remotely.
- All the other settings (fade types, fade times, play back direction,...) need to be set up in the Cue List menu of the AURA webconfiguration. These settings can't be controlled remotely.
Here you can find all remote control options which the AURA offers:
https://help.madrix.com/aura/html/hidd_remote.html
Here you can find all settings, which are bound to a Cue and can't be controlled remotely:
https://help.madrix.com/aura/html/hidd_cue_list.html
Avocado
Post by Avocado »
That makes sense. So Would this be a reasonable flow?
-In Madrix5, create a bunch of Cues with the looks and fade types/times that I am likely going to need.
-Load the Cues into an Aura controller (SD card? Network record? What is recommended?)
-Use my playback device (CueServer, Lighting Console, etc) to send DMX signals via sACN to the Aura to fire off the cues.
The only headache I have with that is I can't use Madrix5 as a "visualizer" to see what my cues will be doing with my playback controls, as it seems the commands I would send to the Aura and the commands I would be sending to Madrix5 are different.
Hi Avocado,
- Yes, for example you can create a Cue List in MADRIX 5 and record the complete Cue List (one large record with all the Cues) or you can record each Cue individually (one record for each Cue).
I recommend to watch the following tutorial. It covers the recording process:
https://youtu.be/TcIvbtti-nk?si=caoM4Vq3kSVo8dEm
- You can use the direct network record.
- You can also record your effects in the *.mrec format in MADRIX 5 and convert these records into the *.dxd file format (this is the file format being used by the AURA) and copy it to the AURA SD card.
Here you will find additional info & instructions:
https://help.madrix.com/m5/html/madrix/hidd_record_dialog.html
- Yes, correct!
Here you can learn how to set up remote control for the AURA:
https://youtu.be/kVWnTI0blc4?si=QP3isgCbbwOqnREH
The only headache I have with that is I can't use Madrix5 as a "visualizer" to see what my cues will be doing with my playback controls[...]
- That's right, but you see the effects in MADRIX 5 before you record them with the AURA.
- You can also use a visualizer software to view the actual data, such as Capture.
