Add Grid proportion in 3D view
reporter
Post by reporter »
Hi
It would be great if you could modify the 3d grid to more accurately represent the view particular installation.
In my instance, I have just installed a grid of tubes 9 x 18 x 16 pixels, but physically, the dimensions are 3.25m x 6.9m x 1m. To complicate things further, I'm using tubes which have two pixels vertically,
There's already a similar functionality to adjust the view of the 2d preview. If that were extended to 3d previews also, it would be a good start.
Thanks,
Nathan
Re: Add Grip proportion in 3D view
Hi Nathan,
thank you for the hint.
We already work on it, but it will still nedd some time.
E.Kirby
Post by E.Kirby »
I found you can replicate this somewhat (but not perfectly) by using the offset when you setup the matrix.
Yes, but this increase the patch size, which could cause a Performance issue, depending on the total patch size.
However from time to time i use this posibility as well.
